Old 02 Apr 2008, 03:39 pm
CREWZIN CREWZIN is offline
Default Re: Damn fog lights..
Mean Green is right on the money. MX-5 (our local GURU) once showed us close-up pictures of the inside of the multifunction stalk. The cheaply made parts inside were burnt and melted because of the heat generated by the draw of current thru the stalk. Why everyone doesn't have the same thng happen is a mystery. I use my fog lights quite a bit (a little less after I saw what could happen) but the stalk still works after 7 1/2 years.
You can replace it yourself without too much problem. After you pick one up, give us a shout and I'm sure someone will walk you thru the changeover. Make sure you buy the right stalk, the one WITH the fog light control...you can get one without the control by mistake.
