Hey 37, thanks for the insight and expertise as it seems as you are in the industry. With luck I'm goin in also, and would understand not givin out trade secrets
Thanks for the tip with the prybar. I found it easier to lift both sides, sway bar doin what it does makes it hard to reassemble.
I have been unable to find a hub/bearing assembly, except for the rear. The front only lists bearing. It appears the previous owner was rough on her, so replacing the whole thing could be optimal- as you stated, don't know if someone hit curb or what not.
Short on cash is main reason I want to DIY. Just bought the PT 2 months ago, and am strapped.
Thanks again
