Originally Posted by cleverklutz
If you replace the fog light bulb with a higher wattage bulb will more draw go through the stalk?
No. The stalk haas a small, minute wire that only supplys a fraction of a watt to turn on a relay. Your relay will see more power draw. If your relay is rated to tolerate the extra current draw then you should be OK. But the stalk has no play in the matter.
