Old 07 Apr 2008, 02:04 pm
CREWZIN CREWZIN is offline
Default Re: Check engine Light
P2096-DOWNSTREAM FUEL TRIM SYSTEM 1 LEAN
From the internet: That means the computer has seen a problem with the rear O2 sensor on bank one. This would be on the left side behind the catalytic converter. We usually just replace the sensor and clear the codes. For the computer to set this code its has seen the sensor failure .
