Re: code p0300 means ??
Bob,
Fault Code P0300 - Multiple Cylinder Misfire
A misfire code in a specific cylinder (P0301-Cylinder #1, P0302- Cylinder #2, etc.) usually indicates a possible problem with a plug or ignition wire. A P0300 code indicates the misfire is random and moving around from cylinder to cylinder. The cause here would likely be something that upsets the engine's air/fuel mixture, such as a major vacuum leak, leaky EGR valve or unusually low fuel pressure (weak pump or faulty regulator).
That has nothing to do with the air bag light or red dot in the middle (security alarm light). Sounds like an electrical fault somewhere.
