Re: changing speedometer
theres really nothing to calibrate,
speed sensors in the trans give the pcm and tcm inputs for vehical speed and that info is bused to the cluster.
so the cluster just takes the input and shows you what its being told
the only thing that would change your speedo would be if you have the wrong tire size for the set pinion factor in the controlers
