14 Apr 2008, 08:37 pm
Re: Grill Lighting
Originally Posted by outfit
I know here in Texas they can be an ass about it.. Here is what i know.
Except as expressly authorized by law, a person may not operate or move equipment or a vehicle, other than a police vehicle, with a lamp or device that displays a red light visible from directly in front of vehicle. So as long as the undercarriage light is not red it should not be a problem.
Also to avoid conflict with other laws regarding required color of lighting devices mounted on certain locations of the vehicle, the actual lighting device itself (i.e. neon tube light) should not visible. If all you can see is the glow of the light being projected onto the roadway, thats ok. .
It also say that you can drive with them ( neon lights, ) on.. As long as you cant see the tubes you are fine..Any color tube that is directly visible from the front, rear, sides (esp. reserved emergenct colors) is strictly prohibited.
And as far as LEDS or tubes inside, The lights need to be mounted below the dash line of the vehicle interior so it will not interfer with the drivers ability to see outside the windows due to reflection off the interior of the window. Otherwise interior neon lights are ok as long as they are not red.
Yeah so we have it bad here...oh and no neon License .. or strobe ...
That is what I heard, either way, I don't drive with them on. I only use them at shows or any other time when I am parked. Hiding the tubes is a must for me because I really hate it when they are badly mounted and you can see them! makes the whole car look tacky.
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
