Blowing Fuses
CARTMAN Thanks for the response..Engine wiring harness has been repaired..Traced LB/WT wire from fuse panel fuse #11(ENG MOD/ABS-TRAC) to the PCM pin #20. With the connector disconnected and ignition key on LB/WT wire reading 12.5 volts and fuse is good. Also all connectors on engine disconnected. PCM connector plugged back in, battery connected and key turned on, the fuse blows. Could I have a bad PCM causing the fuse to blow??
