Thread: Blowing Fuses
Old 17 Apr 2008, 04:58 pm
DragAsp DragAsp is offline
Question Re: Blowing Fuses
Thanks, Checked - No ABS, pulled all the relays in the PDC, plugged connector into PCM, connected battery, key on, fuse blows... So, I'm assuming the PCM is bad. Also ohmed pin 20 in the PCM to the case, it's indicating grounded. Is there any way to check (continuity or otherwise) the engine wiring harness that would cause the PCM to short? Hate to put another PCM in and blow it too. Would a PCM connector pin diagram help to check each circuit in the engine harness? Just pulling straws right now,,,,
