Old 19 Apr 2008, 11:47 am
PTmodrod's Avatar
PTmodrod PTmodrod is offline
Default SRT4 Engine Swap
My engine is on its way out and I am looking into finding a replacement. I have put so much effort into other parts of the car, that I am not really willing to replace it. I figure that if I am going to be replacing the engine anyway, why not do all the performance work I wanted to do right now and save having to pull the engine again for some time. My biggest question is about the similarity of SRT4 neon parts to PT parts, namely the block, transmission (mine is a stick) and driveshafts. The other option is to pull my motor, bore it 10 over, get new forged internals (low compression), cams and do a custom job on the turbo setup later on.
To make my question about the driveshafts a bit clearer, are the GT HO driveshafts notably stronger than normal ones? Same question about the SRT4 ones, but also, will they fit?
Last thing, how is the head on a PT engine? If it could be better, does anyone do porting and polishing?
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
