Thread: Stage I or not?
Old 19 Apr 2008, 01:01 pm
Dream4's Avatar
Dream4 Dream4 is offline
Default Re: Stage I or not?
Originally Posted by AlexJB View Post
Is this S1 kit from Haynes pretey much plug and play or does it require dealer/mechanic shop setup?
The 03s are a little bit more complcated because you have to replace the injectors, '04 & up are a lot easier, but, It is designed to be a self install, as long as you have & can use a 3/8" socket set, and read and understand and follow the directions, they are spelled out very nicely, and if you have an auto trans, the trans learn is also easy and fun to do, you just need to follow all the directions with no short cuts on the auto trans learn if you have one. if you have a 5 speed then it is even less time to do the upgrade.
There is even a 800 help line in the directions if you need to ask a question or two.
'05 GT Dream Cruiser Series 4. No.1109
http://www.alcamar.com/mods/
http://www.alcamar.com/dc4
http://www.alcamar.com/trailer/
