Re: FS: Camber Bolts
Allows you to adjust the camber of your wheels back to factory spec. Without them, when you lower your car, your tires will be tilted on their sides and they'll wear unevenly and prematurely. We only need them on the fronts because the back is a solid axle so it lowers flatly. The front doesn't because it's independant front suspension.
