New to the forum, and need a little help...
I'm new to the forum and need a little help....
2001 running fine; then the tach started jumping, lights got bright, then the motor shut off.... Tried restarting the motor and no go... What happens now is the solenoid sounds like it spinning but the starter will not engage...
Could this be the starter, alternator, or did something else go wrong?
I used a battery jumper and again all you here is the solenoid spinning not engaging the starter.... Your help is most grateful!!!!
Thank you,
Hans
