Re: New to the forum, and need a little help...
Welcome to the forum.
Are you sure it's just the solenoid spinning and not the starter spinning without engaging the flywheel? Found this in a search............
When I try to start my engine, I hear the starter spinning but the engine isn't cranking. What gives?
You have one of two problems: Either the starter drive on your starter is defective and is not engaging the flywheel to crank the engine, or the flywheel has some broken or damaged teeth that are preventing the starter from engaging.
Starters come in a variety of designs. On some, the solenoid is mounted on top of the starter. When you turn the key, the solenoid routes current to the starter motor and at the same time pulls a lever that slides the drive gear mechanism out so it will engage the flywheel and crank the engine. If the solenoid is weak or damaged, it may not be strong enough to overcome the spring tension that retracts the drive gear. So the starter spins but doesn’t crank the engine.
On other starters, the solenoid is mounted remotely. When the starter motor starts to spin, it ratchets out so the drive gear will engage the flywheel and crank the engine. If the drive mechanism is damaged or hung up, the motor may spin but not crank the engine.
Regardless of what type of starter you have, it will have to come out for further inspection. The drive gear (which is sometimes referred to as a "Bendix drive") should move out when the starter starts to spin. The drive gear usually has a one-way clutch that is supposed to protect the starter against damage if someone keeps cranking the engine once it starts. The gear should turn one way but not the other. If the gear is locked up or turns freely either way, the drive is bad and needs to be replaced. If the drive can’t be replaced separately, you’ll have to replace the entire starter.
