Old 23 Apr 2008, 03:53 pm
Dream4's Avatar
Dream4 Dream4 is offline
Default Re: 2004 2.4 turbo High Output
Originally Posted by 05CruisergtHO View Post
On Mine it only gave 5 more hp due to it being an 05 HO stock having 230hp. BUT. it adds about 20ft/lbs of torque through out the power range. Yours being an 04 stock have 220hp, it will bring you upto 235hp and 260ft/lbs of torque. It's somthing to think about latter if you desire a little more gitty-yup plus it does not affect mpg's that much, I'm getting between 270-300 miles per tank so its not to bad. Just dont let your lead foot get bored!!!
It gave you a lot more than 5hp, your factory 230hp was measured at the crankshaft, if you look at your '05 Stage 1 install sheet you will see that the '05 Stage 1 power chart shows 235 hp to the wheels, that is about a 45 to 50hp increase to the wheels, The PT auto has a 20% loss in the drivetrain & the 5 speed about 15% which puts your factory 230 crank hp down to about 184 wheel hp, ,myself and several others with '05 & up GT have had the dyno tests to prove it, it also increases the torque from 245 stock, to 275 foot pounds.
'05 GT Dream Cruiser Series 4. No.1109
http://www.alcamar.com/mods/
http://www.alcamar.com/dc4
http://www.alcamar.com/trailer/
