I have a 2003 PT Limited Edition.
Me and my mechanic have tried so much to figure out this problem. And my mechanic is Grade A I've been going through him for five years.
The problem I am having is that when the A/C is turned on the Radiator Fan is suppose to turn on to cool the pressure system for the A/C so that the heat doesnt cause high pressure and release on the cut-off valve.
The problem I am having is that the Radiator Fan does not seem to want to turn on when the A/C is turned on. However it does work, and it cycles on/off when the engine gets hotter and then when it is not so hot.
We have checked many relays and checked many sensors and cannot seem to fix the problem. If anyone has had the similar problem or knows how to fix this problem, the help will be greatly appreciated.
-Casey
