Old 30 Apr 2008, 08:11 am
CREWZIN CREWZIN is online now
Default Re: tail/dash lights out
I got this from PT Do-it-yourself.net
There are multiple fuses involved with the stop and tail lights. They tie into several different systems including the security system and locks. Rather than post info for 11 different fuses, I'll give the most probable based on your description.
Fuse #10, 40amps in the power distribution center (under hood fuse block next to the battery) supplies power to fuses #1, 2, & 3 in the fuse block (inside the dash). These 3 fuses control tail lamps, RKE-remote keyless entry, multifunction switch(headlight switch), and power door locks.
Once you determine that fuse #10 -40amps is the culprit, check the operation of your brake and tail lights everyday. Don't take safety for granted.
