Old 05 May 2008, 01:28 am
ucantcme's Avatar
ucantcme ucantcme is offline
Send a message via AIM to ucantcme Send a message via MSN to ucantcme Send a message via Skype™ to ucantcme
Default Re: anti lock brakes..
Originally Posted by cleverklutz View Post
My car doesn't have ABS and I think that's one of it's better features. I was very happy when I found that out!
If you learn how to drive without ABS it is a bit better. All ABS does is let you steer when braking, it does NOT make you stop faster, actually it increases stopping distance. I've been in emergency situations where I had to steer around cars and it's no problem as long as you let the brake off when you want to turn. You can actually lock the wheels up, turn the wheel, the car keeps going in a straight line, and then let the brake off when you want to turn. That's a technique I've found handy in winter when coming up to a corner too fast. In winter driving no ABS really helps with good tires as it lets you stop even if not all the wheels have traction. I often lock my wheels fully in winter doing a fast stop, the car tends to go crooked, but it stops very fast.
I would go with the car you like the best. If it doesn't have ABS just drive it until you are used to it. My only recommendation would be run a good quality tire.
That's just my opinion, gained mostly from driving through very crappy Canadian winters. Feel free to disagree.
Ben
Agreeeeeeeeeed! 110%!
Driving in the snow with no ABS is a shock to people, but if you learn to drive without ABS it's a huge advantage. Kind of like learning how to drive a stick shift. If you can drive a stick - you can drive anything!
Snow + Nice tires = No problems. Unless your going 80 and have to stop quickly. Compared to my work vans (With ABS) and my car (No ABS) my car does stop A LOT shorter than the vans. Using that hand-brake is awesome as well
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Limo tint all around, blue neon interior, blue LED windshield nozzles,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Antenna Bezel, Chrome Grille inserts, Dual Catback Exhaust, Scan Gauge II,
back-up camera, and a system containing 2 Lanzar 15" subwoofers and an MA Audio 1800watt amplifier.
Check me out on Car Domain!
