Old 05 May 2008, 12:54 pm
kix000 kix000 is offline
Default Re: Cleaning Interior Upholstery for '06 Cruiser
YES Essentials® products are developed by Milliken & Company, a global textile and chemical company based in Spartanburg, South Carolina. I work for Milliken, saw your post, and would like to respond.
YES Essentials fabric did not launch in the PT Cruiser until the 2007 model year so your 2006 PT Cruiser has another fabric. With that said here are some tips that might help you remove the ring from your seat:
It sounds like you got a bit too much soap in the fabric during your cleaning process. So, you need to basically break down the soap and get it out of the fabric. Here's the trick...Get a cloth with water on it only. Carefully dab the area to re-wet the soap and get it out. Dab the fabric as much as you can with your cloth, careful not to reapply the soap you are removing. Once you have all of the soap out, dry the fabric with another cloth as much as possible (more dabbing). Let the fabric finish drying with a dry cloth or paper towel on it - something that will help absorb the water while it is drying. This should do it.
