Re: Changing wheel bearings, Press required?
hey 37plymouth i have a quick question for you. im currently in the middle of replacing my right front wheel bearing. ive read your breakdowns but just wanted to make sure im doing this correctly. is it safe to say that all the bolts attached to the hub/bearing assembly need to be removed? thanks for the info you've already shared.
