Old 09 May 2008, 10:54 pm
PTmodrod's Avatar
PTmodrod PTmodrod is offline
Default Re: Chrysler back logo
The best thing to do would be to shave the trunk. That way, it would open via a button on a remote or somewhere else on the car. If you do that, you may also want to put in stronger struts so it opens up by itself once the button is pressed. A cheaper way would be to remove the badging as cleanly as possible (not sure but it will either be held on by sticky stuff or by small pegs into the bodywork) then over the place where the handle used to be, make a smooth gloss black rectangle that will fit the exposed part.
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
