Old 10 May 2008, 07:26 pm
CREWZIN CREWZIN is offline
Default Re: Throttle body install 06 touring
Originally Posted by discovering06 View Post
Does anyone know how hard it is to install a throlle body?
??? Do you mean a throttle body spacer, or a new throttle body?
If it's a spacer ...forget it, waste of money! If you need to put on a new throttle body (for some reason, it's pretty easy, just a couple bolts after taking off the air intake tube, but you should tighten down the bolts after installing a new TB to the correct specs using a torque wrench.
