Thread: WGA Question
Old 13 May 2008, 10:08 am
03electricbluegt 03electricbluegt is offline
Default Re: WGA Question
Adjusting any WGA on the PT is a chore due to the heatshield and the heat of working on it after running it. You might be able to temporarily remove the heatshield until you get things dialed in but I would limit the amount of driving you do with the shield off. The stage 2 WGA is adjusted with a threaded link on the end of the WGA arm and a jam nut to keep it in place.
Good luck
Brian
