Re: 06 turbo check engine light
Welcome to the forum.
Hopefully nothing bad like a leaking head gasket or worse. 9 out of 10 times that code is cured by the new plugs and wires. Do you notice any leaking or missing coolant? Is it running hot at all? Does it shake all the time or mostly at idle?
You've run into the old adage saying "all bad things happen after warranty runs out", It happens to all of us.
