Maybe you didnt hit a 12V source. The wire that is used for the headlight/guage lighting is a pink wire. You can find it by opening the fuse panel to the left of the steering wheel. Then unscrew the fuses blocking two groupings of wires. There should be a group of eight wires right behind the fuses (a little above) The pink wire should be the top right wire of the group. This is the wire i used and have had no problems with my autometer guages.
Set the geere shift for the high gear of your soul!!!
http://interactive.colum.edu/students/jsoltes/IMP/projects/project%201/ptperform.html
