Re: Grille Lighting
Originally Posted by DJmart
They are just regular LED's sitting in LED holders... pretty basic.
They are mounted a ways away from the fog light bulb, so heat really doesn't get to them.
EDIT:
as you may notice the foglight bulbs are independent from the LED's, there is a switch in the car for the LED's, and obviously the fog lights in the multi-switch.
I was thinking about doing the same thing with my headlights with red LEDs. My only worry is about moisture getting into the housing. I live in Florida, so its pretty likely. Id assume you'd need silicone to seal them properly. Just as a note, I like your grille, maybe you could get a couple more of the lights you used at the top and put them in the lower half.
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
