  #12 (permalink)
Old 20 May 2003, 05:43 pm
Gear_Head Gear_Head is offline
Installed the dual stage boost controller bracket (supplied with the kit)onto the controllers in a vertical position. Then turned the whole assy to the horizontal position with the 2nd stage controller on the bottom, and the adjustments pointed toward the front of the cruiser. Removed the 10mm nut on the vac controller for the cruise control. Placed the last bracket hole on the stud and replaced and tightened the nut. This mounts the controllers in the horizontal position. Called TurboXs and asked if it hurt performance to install them in the horizontal position and they said they didn't think so. Ran with the controllers upright, and then horizontal and I couldn't feel any difference or see any difference on the boost gauge or in the EGT gauge. This position made it easy to "pretty up" the setup. I'll try to borrow a digital camera and see if I can post some pics.
