  #11 (permalink)
Old 21 May 2008, 08:42 pm
ucantcme's Avatar
ucantcme ucantcme is offline
Send a message via AIM to ucantcme Send a message via MSN to ucantcme Send a message via Skype™ to ucantcme
Default Re: Lame Gas Mileage...HELP
Originally Posted by Unseenspirit2002 View Post
Umm....yes way i get that kind of mileage. We're talking 12.5 mpg and no I'm not going to forget how many miles to a tank because it all counts brother and if your getting better mileage while your rolling through CO then your ECM hasn't had time to compensate for the thinner air, we're talking a 20% drop in HP as opposed to Sea level. I'm from NJ, born and raised and been back and forth 4 times for visits over the past 14 years. Also to answer some more questions, the oil was fresh when I purchased it and I had it changed to Mobil One 5w-30 April 4th and have maybe put 500 miles since then. Also at the time of the oil change I had them replace the air filter. I'm not sure of the last tune-up of the car but the plugs, when I pulled them were clean and the electrodes had no visible wear. The wires, OEM, were clean with no visible breaks or cracks, and a check with a digital ohm meter showed that each was with in the acceptable tolerances. As for the condition of the fuel filter I had that changed last week just to see if it made a difference and thus far, no. So I'm baffled by it, I'm throwing no codes and the engine and whole car is lickably clean, literally. I'm not leaking any fluid and I also had all the brakes replaced with new rotors and ceramic pads, they aren't dragging. I'ver run some fuel system cleaner through it and I'm about to just say screw it and run some seafoam through it too...(SMOKE), so otherwise I'm clueless.
Sounds like everything is okay... I don't see why your getting such bad gas milage.
Maybe you can disconnect your negative battery cable for like a half hour and then start driving it again. So the PT computer can learn (Again) how you drive. Maybe the person that owned it before you floored it from stops and now the PT knows that your going to floor it and therefore acts like you are flooring it all the time.
Sorry if I am of no help - just trying to help!
My Baby:
01' Taupe Limited PT Cruiser w/ rear spoiler, Drop in K&N Air Filter, Limo tint all around, blue neon interior, blue LED windshield nozzles,
In-dash CD/DVD/Radio made by Jensen, Vent Visors, Chrome Antenna Bezel, Chrome Grille inserts, Dual Catback Exhaust, Scan Gauge II,
back-up camera, and a system containing 2 Lanzar 15" subwoofers and an MA Audio 1800watt amplifier.
Check me out on Car Domain!
