Old 22 May 2008, 09:13 am
PTmodrod's Avatar
PTmodrod PTmodrod is offline
Default Re: Grill Over-lay '06
Does the new grille have the same mounting at the top as your 06 grille? It sounds like the same as mine in how it mounts. If it has the same mounts, you may just be able to trim tyhe bottom corners to fit the new style grille. Could you post a picture? I will see if i can find the Autotechnica grille i the mean time to get a look at it. Glad I can be of assistance.
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
