Re: ceramic vs. semi-metallic brake pads
im going with Hawk Ferro-Carbon pads
"race-level" braking = increased rotor wear, noise, and dust
I will never go back to semi-metallic or ceramic again.
it doesnt compare to the stopping power
it makes the car feel like a BBK was installed
brake dust is an optional and stylish
Nevin.
03 SRT-4
68 Mustang Coupe
05 GT Cruiser H.O. — 245hp/283tq @ 15psi
3 in intake, 2.5 in catback exhaust, Stage 1 PCM, Mopar bov, Stage 2 WGA, Check valve, 180 deg T-Stat, Ngk 4306 plugs, 10mm spark plug wires, Energy Suspention MM inserts, upper/lower hardpipes, hawk hp+ front/rear pads, Drilled/slotted rotors, steel braded front lines, Mopar 26mm Swaybar, energy suspention swaybar bushing, energy suspention swaybar endlinks, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Kobalt catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge, APC Non-turbo strut bar, 3in DP, 3in O2.
waiting to go on 3in stright pipe, ported turbo, 682cc
