  #11 (permalink)
Old 25 May 2008, 12:22 pm
terball's Avatar
terball terball is offline
Send a message via Skype™ to terball
Default Re: HID Conversion Kits
Hi, I have installed 6000K HID's in the low beams and 3000K in the fog lights. Both kits are 9006 and the majority of HID kits on the market come with the straight connector bulb. This is not a problem for the foglights either since there is enough room in front of the wheelwell cover. The low beam ballasts in mine are mounted right up beside the bulbs in the headlight assembly, and the foglight ballasts were mounted the same way. I had some friends at a performance shop install mine and both installs were done in less than an hour. They take off the front wheels which makes the job much easier, and the foglight install required them to unscrew the wheelwell cover (3 screws) in order to get the ballast into place. I bought both kits from EBay and the seller was "Intense HID". These kits are Japanese with a 1 year warranty and they have performed great. The difference is absolutely phenomenal. You don't have to pay huge prices for these kits to get quality so don't let anyone tell you different. Check out the 2 websites- www.intensehid.com or Welcome to Xenon-Vision :: L.E.D & HID Lighting System.
