Old 25 May 2008, 07:52 pm
Mean Green Mean Green is offline
Default Re: Car stalled 3 days after work done
Originally Posted by CREWZIN View Post
Mean Green, here's the thread that goes thru all the problems R-I-PT went thru with bad dealers.
06 turbo check engine light
R-I-PT,
Two main things bring the engine to a halt, fuel and spark. Although your mechanic might be good, sounds like he may have left something electrical loose. Check your battery connections and if you can all the wires to the coil. Also check anything he might have disconnected to clean the TB and replace the MAP sensor.
Ahhh, so the coil was replaced as a reach. Crewzin is right. Double and triple check everything.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
