Do not forget that you need a ground.
If the gauges came with a seperate ground wire make sure what ever you connected it too is truely grounded. I have seen metal stiffeners under dashes that are isolated from the chassis and hence are not grounded. Also, if the gauges do not have a seperate ground wire with the expectations that they are being grounded through the housing, you will not have a ground if they are in a plastic guage pod. You will need to add a ground wire.
Dave Clement
\'03 GT, Electric Blue
