OK, here's what I did. You don't use the battery itself for a hot line. The fuse box in the engine compartment has 4 spare fuses that will safely get you a hot line. Connect the wire to one of those fuses and run it through the firewall.
If you get down under the dash (from inside the car) you'll see a large black circular grommet that has a couple wires and the hood release cable going from the inside of the car to the engine compartment. There's enough room to slip a couple more wires through that same hole.
Myself, I put a lighted switch in the center dash console and ran the hot wire to the switch and back out the hole in the firewall down to the undercar lights. This way I can tell by the lighted switch when the undercar lights (I have LEDs) are on. Grounding of the lights can be done anywhere there's a ground depending on how your lights are wired. Now my lights were a little more complicated as they are computer controlled so the hot from the lighted switch went to the computer before going out to the LEDs but you shouldn't have to worry about that.
You must have a switch with the kit the lights came with and it should have instructions on which wires go where.
Back to your original question....don't use the battery itself for the hot line. You owners manual will tell you which fuses are the spare ones in the engine compartment but here's a reverse picture of the outside fuse box with the spare fused colored pink.
