Re: Door lock problem - DIFFERENT - check it out
What would I be looking for? I've had the door panel off to replace the switch itself, and the door will open with the pull handle on inside and outside just fine. The door unlocks if you hit the passenger side switch, it's just the driver switch. It really seems to be some kind of electronic issue to me, since everything else works, but any help is appreciated.
