Originally Posted by Deathstar
Will my stock CAM gears work with this cam? (I’m hoping so since the duration is only 6 degrees longer than stock) I shouldn’t need adjustable cam gears right?
Crane clams “good idle quality” with this cam, but is that “good” for a cammed up motor or good compared to stock? Any experience with this?
Will this cam raise my redline or is that determined by the computer?
Will the stock rings hold up against the increased compression? Or should I expect increased oil consumption?
Will my PT computer and injectors be able to maintain the proper A/F ratio? (the cams not that wild so I’m hoping so, since you're already running a #12 crane cam with stock PT injectors/computer)
Will the engine require some level of “tuning” to run well, or will the computer be able to make the adjustments on it’s own?
My #12 idles good, just a enough lump to make it sound different, but does not hesitate any when reving up from idle.
The stock gears will work with the cams, you just will not be able to fine tune them. I have not got onto the dyno yet, but I am guessing the -3 exh, +2 intake will make them perfect. But even at zero, they are surpassing stock performace in a big way.
The cams will raise your redline power, but not the redline cut. The computer will kill the engine before it reaches maximum power now, which is around 7,200 RPM.
Your stock internals, computer, injectors are fine. The injectors are good for some pretty good HP and the computer is pretty smart. Only thing is that it will always try to run rich to be safe. A AFC computer will allow you to lean it out for a little more power.
I am getting a lot of my tunning info from the SRT guys who are building lots of power in their cars. We have the same motor as them but there are a lot more of them racing than we are.
Many of the SRT guys have tried to convice me to go Turbo, but I felt that my project car is more "old school" in styling. I wanted to keep the motor NA, loud and quick to rev on the power. That is a great combination for street performance. Not many places other than the track, to kick it for more than 15 seconds anyway. Stop light to stop light in my town is much shorter than that. But the shock on the guy's face next to me who has a turbo is great. He does make more top-end power than I do, but never gets to use it. I launch, make lots of noise and already slow down for the next street before he gets to make any power. :-)
Now on the highway, it is a different story, I can kick it, quickly move ahead by a good car because of the quick power, but about 3 seconds later a well built 50trim turbo car will blow by me like I was nothing.
I think you'd be surprised how fast my SRT-4 gets off of the line. Still with the stock turbo, but with the power mods I have power is almost instantaneous and the suspension is set up for the track. One of the best mods I invested in is the Aeroforce Interceptor scan gauge that comes with a shift light. Most people think you run it to almost redline and shift, but though my rev limiter is 6200 my "sweet spot" is 5500 and that's where the light is set. Used to be bouncing off of the rev limiter was easy in 1st and 2nd gear as the power comes on so darn fast, but I never miss the sweet spot now.
Besides, with almost $6k into my car, it had better do what it does or my wife would kill me.
Still, your ride is going to be special. My wife has an automatic '04 na PT and while being a great car to cruise in it is slower than frozen mud. You are going to surprise a lot of people. There would be a lot of people over at
PTCrew.com - Learn it or Burn it. with na PTs who are looking for some more punch. If you haven't been there, there are a lot of PT gearheads who hang out there.
