Old 09 Jun 2008, 12:40 pm
CREWZIN CREWZIN is offline
Default Re: Is it a fuse or wiring?
Patrick,
Welcome to the forum. You have an unusual situation. The door locks are controlled by the RKEM (Remote Keyless Entry Module) located in the middle of the dash behind the air vents but it has nothing to do with the headlights. Headlight and fog light problems usually turn out to be the multi-function switch on the steering column.
As far as the fuses go, on the inside fuse box both the #3 and #10 fuse say "RKE" so you might what to double check them and the number #19 is for the right headlight, #20 for the left.
