Re: Whats the difference between key trouble codes vs odometer ones?
Update on my MIL problem. Apparently the key on 3 times routine works. The reason I got a "done" with no codes was the code was "stored" but no longer "active". My Innova code reader was way off. The stored code was for a small leak in the evaporative system (like loose gas cap). Service dept cleared the code and put a new gas cap on and checked several other places that could cause this. No charge as I have 1500 miles left on warranty. I plan to flash update my code reader and see if it can read 07 codes then. Thanks for the input Crewzin.
Mike
