Right Low Headlight + Shifter light Dead HELP
tired wet cold and frustrated
2006 Pt Cruiser
Went and bought a new silver star headlight for the passanger side low beam
put it in and found it still was out - worked with high beams on - same with new bulb
Tried new bulb in left side worked no problem
Tried left bulb that worked in right side on low didnt work
Wife noticed afrer when I got back in that the shifter/middle console light PRND etc was out/not working
even when turned on from the switch on the wheel
Checked all the fuses under the hood and am wondering
Is the fuses under the hood all the fuses?
Cant see any in the car? is there?
i read somehwhere the L and R are diff volts/fuses
but have had no luck
Any advice be apreciated
desperate - if not ill have to serice monday
:C
