  #14 (permalink)
Old 22 May 2003, 02:07 pm
Cal Cruzer Cal Cruzer is offline
You won't screw up the odo if you do a -1 or -2 application. Any good tire shop or online retailer should be able to give you the right tire size to maintain the proper rolling circumfrence for your application. If you can't find anyone let me know as I have written a spreadsheet (but it is in the much un-used Lotus) that will compare five different sizes to the stock size and return the difference in rolling circumfrence in inches and if you know your gear ratios (trans and final drive) it will estimate land speed or engine RPM depending on the info you input.
