16 Jun 2008, 10:12 am
Re: Rubber Scuff on Paint
Originally Posted by yaschief
I was on the job yesterday when the Local 361 Pusher came over to me and said "Bro, we got a problem...one of my guys tagged your ride."
DOH!
Well needless to say I was pissed and we walked over to look at the damage...
Black scuff from the center of the Passenger front door to the gas door! the right side looked like it had a tire scuff decal on it. About 1 inche wide by close to 50 inches long!
Matty sez "Bro, I'll cover the cost, just let me know what it is."
Black on Silver Metallic...not pretty...
Seems the guy was backing into the the job and his bumper rubber touched the passenger side.
Took a closer look, no dent, no crease...took a can of WD 40 and a Scott shop towel and sprayed it down and let it sit for a few minutes. The edges wiped away and I could see the clearcoat was not damaged...OK we may have a chance here.
When I got home I took out my Dremel and the buffing pad set it came with and used the bullet nosed buffing pad soaked in WD 40 at about 3500 rpms and slowly worked the scuff in long easy strokes, spraying WD on it every few minutes.
After about 5 minutes it started to peel away and left the clear coat undamaged. Took me about 45 minutes to get it all off.
I then washed it down with Mothers wash and did a coat of Mothers Swirl remover and a top coat of Carnuba with the round buffing pad.
Not a mark to be seen!
Now, should I tell the guy I had to have the side detailed or just settle for a
6 Pack of Bass?
Tell him the truth...hopefully, he'll give you something in return for being honest.  IF not, at least you did a nice gesture.
