Thread: stage 3 turbo
Old 22 Jun 2008, 12:22 pm
CREWZIN CREWZIN is offline
Default Re: stage 3 turbo
Your forgetting the ECU (Engine Control Unit). It's in the picture of the kit you linked to (square unit). High Flow fuel pump assembly, pressure regulated fuel rail assembly, new 3 Bar MAP & TIP sensors ....... yea, if you get it all it might work on the PT.
Also, something else you said that's not right. You said the stock Turbo & Maniflod are the same on the SRT and PT. The manifolds are completely different and if you try to use the manifold from the SRT-4 on the PT, in won't fit in the engine bay.
Your really better off just sticking with PT Cruiser parts that are made for the PT. Stage 1, BOV, hard down tube, boost controller; all that, which fits just nice into the PT will give you all the performance you should need. Don't forget to upgrade your suspension, good tires, flowthru exhaust and some sort of cool air intake.
