Originally Posted by JoeHundredAire
I'm still curious as to whether or not the mounts are problematic on the PT? At 29K or at 42K miles, no car should need new motor mounts unless something major has happened to it.
I'm hearing about them more and more. If you saw the flimsy rubber on them you would be surprised they last as long as they do. The mounts (torque struts) for the Neon SRT-4 and the PT are interchangeable, but the rubber on the mounts for the srt is much stronger. If needing replaced I would get the srt ones or ones that are polyurethane filled. They will last much longer.
