Old 25 Jun 2008, 05:47 pm
PTmodrod's Avatar
PTmodrod PTmodrod is offline
Default Re: Dome light removal
Originally Posted by DJmart View Post
Now, question is.... are you using conventional LED's with the two leads on it? Or are you buying the proper fit bulb with the LED's fabricated inside the bulb itself?
Well my current plan is to use these large, heavy duty LEDs that I currently have. They have a standard 2 lead setup on them and I was just planning on playing it by ear as to how I would hook them up. I probably wont purchase the bulb ones unless I completely cant figure it out.
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
