Old 27 Jun 2008, 10:08 pm
Default Re: Transmission question
Welcome, Scott.
Don't know what you mean by "serviced". There are no adjustments in the tranny - it's all electronically controlled. For about $200, you can have the tranny flushed. Be sure you find a place that has the flushing machine and be sure they use ATF + 4 fluid. You can have the pan dropped & drained & refilled, but that only gets about 1/2 the fluid (rest is in torque converter).
The auto flush should be done at about 50,000 miles, so you'd be early, but an early 2001 with only 26,000 miles means it didn't go on long trips and did a lot of shifting over those years.
