Re: oil light on and off...even after oil change
The most important and missing piece of information is the weight or viscosisty and the base. If you are using a 0W30 fully synthetic, you may not have a real problem. Carolina in the summer. What is ambient temperature when the ding ding occurs--is it always with engine going in to a low rpm with load such a slowing using engine drag or when you come out the hole slow and lazy. Also what oil filter are you using? yep, they do perform differently and can cause problems
