Old 05 Jul 2008, 01:41 pm
PTmodrod's Avatar
PTmodrod PTmodrod is offline
Default Re: Rear driver's side door will not open at all!
Well you shouldn't have to cut through the interior panel, you can just remove it and it will be in good shape. Then you have all the room you need to work inside the door itself. If something is stuck, you should be able to see the problem. If you can't, you may need to buy new inner workings for that door.
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
