Whoa!
Ron, On your 01 you should have had both horns, a high and a low.
Teekypt,
In 03, Chrysler did away with one of the horns in their cost savings mode. Sorry, I'm not sure which tone (high or low) they did away with. So, you have only one horn, so taking that one out and adding the Road Runner horn should be a snap ...if you wanted the RR horn going off when you hit the steering wheel. If you wanted a separate "beep beep" you'd have to had a horn button somewhere. Like I did with the Aooga horn. Added a push button in the center console. The square red button on the left. The red rocker button on the right is for the undercar LED lights.
