Old 17 Jul 2008, 03:11 pm
2004PTGT's Avatar
2004PTGT 2004PTGT is offline
Default Re: CV shaft after hub and bearing replacement?
OK I'm back. The problem came back and it wasn't the brakes. I'm now so disgusted at this car I want to dump it at the stealership that fixed the car.
When I go above 60mph+, the shimmy and thumping starts, gets even worse when I have to go slight right at high speed. The dealership did not replace the right half axle shaft. Since it's still under the 7/70 powertrain warranty, should I just go and get it replaced?
I would be out of ideas if that doesn't fix it. Any mechanics in metro Detroit area you guys can recommend?
Thanks!
