Old 20 Jul 2008, 10:54 am
onedivinehammer onedivinehammer is offline
Default Re: Bad Fuel Pump/Filter or what?
UPDATE:
Well, I went through the codes. I had a couple, but mainly it was p0340 & p0344 (camshaft position sensor issues.) So I swapped the CPS out and $50 later it seems to work. At the same time I swapped out the plugs, which I'm embarrassed to say were the original ones (98k), with NGK 2314, and the wires (again embarrassed to say the original ones) with Magnecor 8.5mm competition. The car is running great again! We'll keep an eye on it to see if the fuel pump is the problem. Typical fuel pump life is 100k.
PS - I did not get the Magnecor turbo edition wires. The only difference is that plug #4 (on the turbo) has a 90 degree angle going into the distribution cap. I had no issues with fit.
